seeta gunti
Hello Florian,
Are you looking help on how to monitor the lift or drag at one point on a surface? Generally drag or lift is calculated based on either a plane or line where surface area is measured. And Fluent gives us the drag or lift on boundary walls. If you want these values on a derived surfaces, you need to write the UDF.
Seeta
