Sandeep Medikonda
Hi Kiran,
  You can still use the mid-surfaces to extract the mid-surface. Are you seeing any errors?
  I would recommend you to use the range option and if you notice any Gaps between the generated surfaces, use the Extend tool along with the Shared Topology option.
  Hope this helps.
Sandeep
Best Practices to post on the Student Community
