Ashish Khemka
Thanks for the update. The error message indicates rigid body motion. What did change between static and transient analysis? If it is same model then I am not sure what might be causing this. Also, model may be required for debugging and I cannot d that. If you can describe more on the problem, that may help.
Ashish Khemka
