.dxf import tends to be a bit hit and miss as it's an older format and seems to vary between codes. Depending on the CAD tool, can you export STEP or ACIS? Those are generally more reliable.
You also need to be a bit more specific on which ANSYS product you're using, eg SpaceClaim, DesignModeler, Fluent Meshing etc.
