Naresh Patre
From the images, it appears that there are 2 bodies. Due to this, the inflation layers are not getting transferred from one body to other. You need to select the wing faces from both bodies on which you need to grow inflation layers. Also, make sure that you also select both bodies in Inflation settings.
I am not sure if there is any particular reason behind having 2 separate bodies. Can you try combining them into one and then try generating inflation on wing faces?
