ballisticme
Dear Karthik,
No, it does not prevent the flow.
Fluid would still flow from the inlet (higher pressure) to the outlet (lower pressure) region. In a porous media, the confining pressure tends to affect the material property by reducing/altering the porosity and or permeability while fluid still flows from inlet to outlet. That is how a typical petroleum reservoir works.
Thanks,
Yakubu
