If you set two surfaces on the inlet plane:
  • lower one high enough to include the waves, set using open channel
  • upper one set with an air velocity
You may see some odd effects near the inlet as the wave trough and air inlet don't quite tie up but the remainder should work, and it should sort itself out fairly quickly. Try it in 2d as it should work/fail fairly rapidly.
