Aniket
You might not be able to select the node interactively, but you should be able to use the Named selection based on a worksheet to select the node.
Please check:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v192/wb_sim/ds_NS_worksheet.html
 If you are unable to access the link above please see this post and this on how to access help if you are using 19 or above.
