Gojko
I am facing some strange problems now:
Error: Divergence detected in AMG solver: pressure correction
Error Object: #f
I assume it is because of >infinitive< vortex that occurs in my flow.
Once again, I am uploading very simple geometry from which I am trying to learn.
Iterations are OK until 10 and than continuity goes up
R (Right): velocity-inlet: 10m/s
L (Left): pressure-outlet: Gauge: 0 Pa
Also I have tried:
-with similar geometry as original post and in that case it works, so I assume boundary conditions are not case of causing problems.
-with extremely big enclosure it works fine until 20 iterations and at 90 stops with: Error: Divergence detected in AMG solver: x-momentum
Error Object: #f
x is flow direction
 -Doing finer mesh on the  a) edges b)faces which had improved results but still ran continuity to the sky
I found some ideas on using bulk conditions and am still trying to understand them, but do you maybe have any other ideas how to face this problem?
Kind regards
Gregor
