rounaksingh
Hi Jathin,
In my knowledge ANSYS Electronics Desktop does not support slurm scheduler, So you will have to write your own shell script. Use the ANSYS help files to understand the commands to be run.
I have run only HFSS simulations on slurm. But it should be the same. Do you have experience with linux command line? Also, put some tags on your post so that it is searchable.
If you have experience then I will send you some commands which you can try. Let me know
