DrAmine
Which kind of guidance do you want? Running it on a supercomputer without knowing which scheduler and the underlying architecture are deployed.
If you are running on such machines (which I made in the past) the first contact will be the admins of the machine. Regarding UDF's: I recommend here to launch the case with the UDF library loaded into it. This would avoid necessary compiling stage.
