asamaiyar
Well the best way is to calculate the impedance using analytical formula in the books. And try both 'h' and 'w' to calculate the port impedance (try to mesh your ports really good because sometimes initial mesh is not good enough). I believe the solution should be very similar. But if not, use the one which is closer to analytical.
Hope this helped!
--AS
