Sandeep Medikonda
Hi Luis,
  Yes, see in that example that was shared we had a gravitational load which was done in static. You can just do a harmonic analysis if you want to set up a frequency load or a modal analysis if you want to just look at the natural frequencies.
  Note that both modal and harmonic analysis are linear analysis and you are limited in terms of the contacts and materials you can use.
Sandeep
Best Practices to post on the Student Community
