Hi Zach,
I ran your 4 layer shell model in Explicit Dynamics and saw the error. You have to RMB on Solution and select Open Solver Files Directory. In that directory you will see admodel.log. In that file you will see...
Checking model setup.....Please wait
Error ! Invalid Material Data for Rubber. Incompressibility Parameter D1 must be non-zero.
Error ! Invalid Material Data for Elasthane 80A. Incompressibility Parameter D1 must be non-zero.
Error ! Invalid Material Data for Elasthane 55D. Incompressibility Parameter D1 must be non-zero.
In Engineering Data, put a non-zero value for D1 for these three materials and the solver should at least start.
