Keyur Kanade
As ANSYS employee, I am not allowed to download attachments.
As per the images you have inserted, I can see a cut section of the mesh. But I can not see entire geometry or where mesh is failing.
If you are getting error in meshing, please use right click on the message and use go to problematic geometry. It may give location of problematic geometry. You may want to modify geometry at this location in DM or SpaceClaim. At the same time, you can use virtual topology if required. You can use local edge or face sizing as well.
Keyur
