The grey colouring implies that you've adjusted one (or more) dimensions or constraints to create an impossible design. Work through the model to see which dimensions conflict (angles, radii tend to be the common ones) and delete the offending dimension or constraint.
An example would be a line is set as a tangent to two circles with a length and then you've changed the diameter of one of the circles.
