samyak1902
Hi Sandeep,
In my case the loading conditions are:
1. The rotation speed of 600RPM is to be applied on the surface of the shaft hole of the driving gear.
2. The 35 Nm torque is to be applied on the shaft hole of the driven gear.
Is it possible to simulate gears in static structural on the basis of given loading conditions as both the gears will be moving and none of them will be fixed?
Samyak
