zjuv9021
Thanks Peter.
Could I wrap the salmon part around the tubing, in essence creating an outer tubing wrapped around the manufactured one, rotate the end of the straight tube a fixed degree (e.g. 30 degrees), and then lock the salmon wrapped tubing in my second step and then displace or push my manufactured tubing through this locked tubing path?
Thank you,
Zach
