sameerfares
Hi Karthik,
if i look at this cross section  in plane view, the section is rotated but i don't know how much it is rotated. i need to rotate it so it is level. In other words, the horizontal lines in the section need to be parallel with global x and vertical lines of the section need to be parallel with global y.
 The cross section needs to look like this. The section i send earlier is rotated by some angle. i am not sure how much. i need the rotation angle to be zero as shown below. Thanks!
Thanks,
Sam
