Sandeep Medikonda
Jon,
  Use the MPC formulation:
For the specific case of Bonded and No Separation Types of contact between two faces, a Multi-Point constraint (MPC) formulation is available. MPC internally adds constraint equations to “tie” the displacements between contacting surfaces. This approach is not penalty-based or Lagrange multiplier-based. It is a direct, efficient way of relating surfaces of contact regions which are bonded. Large-deformation effects are supported with MPC-based Bonded contact.
I often find this table from the manual very useful:
Sandeep
