asimghalib
Actually I have checked that and based on it i was able to start a simulation. The simulation is of a normal dipole antenna and on a normal PC it takes one to two minutes for completion. when i run the same file on HPC, it has took more than 10 hours, but still the simulation is running. its not giving any error but it should not take so much time. i dont know what is the problem...
Secondly how can we check the different results like S parameters and radiation pattern or can i copy the simulation file from the HPC and then observe the results in the Graphical user interface...
