mozeer
this is my geometry, its a storm water trap with an internal and external  chamber. the bottom part of the internal chamber has a basket (the brown and green part, the brown part is solid since i want to simulate the basket as half full. the green part is my porous media volume)
thats my meshing.
in fluent I am putting the following parameters:
Type: Pressure-based
Velocity Formulation: Absolute
Time: Transient
 gravity -9.81
VOF multiphase model
N of Eulerian Phase: 2
Formulation: Explicit
Interface Modelling: Sharp
k-epsilon realizable turbulence model
Phase 1: air
Phase 2: water
Surface tension: 0.072 constant
cell zone conditions
i have got the values for porous media from experimental work, plotting pressure against velocity as per Workbench guide.
Boundary Conditions:
Water Inlet (velocity-inlet type)
V: 0.45 m/s
Initial Pressure: 0
TKE: 1
Epsilon: 1
Phase 2 fraction: 1
Outlet (pressure outlet)
top (pressure outlet)
Solution Methods:
Pressure-Velocity Coupled (i have tried PISO as well)
Pressure: PRESTO!
Momentum: Second Order Upwind
Volume Fraction: Compressive
TKE: First Order Upwind
Turbulent Dissipation Rate: First Order Upwind
Transient Formulation: First Order Implicit
Solution Control:
Flow Courant: 200
Eexplicit RF
Momentum: 0.3 (i have tried the default as well)
Pressure: 0.3
Under RF
Density: 1
Body Forces: 0.5
TKE: 0.6
TDR: 0.6
Turbulent Viscosity: 0.5
Discrete Phase: 0.9
std Initialization from inlet
Time step size: 0.001(I have tried 0.01 as well)
N of time step: 1000000
would be great if you could help.
Thanks
Ikhlass
