jonsys
Hello Peter and Sandeep,
thank you for your support.
Please take a look at the picture;
a - two glass panes, no interlayer;
b - two glass panes with interlayer;
c - 1 glass pane with thickness equal to (2 x glass + interlayer) thickness of b.
I can see from the analysis that Bonded MPC formulation gives the same result as shared Topology. I have been using the latter so far.
But with that, I keep getting the result as in "c", even though I have a laminated one and should get results as in "b".
This made me think that probably defining some other contact would be the solution.
1
