asimghalib
This is the same problem i have faced and i had to struggle alot.
The procedure ANSYS works is that before it tries to solve any matrix, it looks for the required space on the RAM, if the RAM is not sufficient enough to handle that matrix, it will not even start the simulation and will give you the error. I talked with the ANSYS customer support and when they and I debug the problem, we got the same reason. .
