Sandeep Medikonda
You can generate calculated values at multiple locations and display at the same time.  In Results add a calculated value and go from there.
To specify an user-defined range. please see this section of the help:
To specify a variable range:
Under Appearance>Variable range, select User-specified.
Enter the Minimum value for the range you want to display.
Enter the Maximum value for the range you want to display.
By default, Clip to range is selected. This hides any data that is outside of the specified range. If deselected, data that lies outside of the specified range will turn light red or light blue, depending on whether the variable is higher than the maximum or lower than the minimum (light red is higher, light blue is lower). The image below shows a user specified variable range with Clip to range selected (left) and deselected (right).
Sandeep
