Please describe in more detail what you are trying to model.
You can draw solid bodies and define contact between the flat bodies and the cylindrical body. A feasible model would have a fixed bottom plate, and a top plate on a vertical translational joint. A joint load can apply a force to squeeze the cylinder between the flat plates. Frictional contact would be needed, otherwise the cylinder can slip out from between the plates.
