masaki kamino
Thank you for answering my question.
About your pointing out , I had about ninty percent RAM when the error occered.
By the way , I solved the problem.
Cousing is that I simulated each model by the HFSS version 13 and version 19 in the same computer in the same time .
I use each version in difference computer ,as a result , my  compute "DELL256v4" can have enough memories and simulation is completed.
Thank you for your cooperation .
