Tony
Hi Peter,
That's the problem , I have only lines. In fact what I want is a surface (a rectangular) with 1metter as width and 2metters as height. Where is the tool pull?? are the boundary conditions entered in the SpaceClaim or in thee Ansys Mechanical while meshing ?? Because the problem I'm facing up now is the geometry that doesn't fit when I try to double click in the model . Thank you
