Max4
The values are changed and assigned during the simulation. By check the existence of the variable, do you mean the " r " if I use " r = RP_Get_Integer("..")"?
In my UDF, can I just write "RP_Get_Integer("..")" so that the if loop can affect the change on this variable if the condition is met?
Maxime
