hassam
Thank you for your response Peter.
I have extracted a beam on ansys using the extract beam command. The results are displayed as shown
When i move it to the mechanical only half of the model is displayed. Because I may have applied section view. Moreover what material assignment should be applied to beam since it is just an empty space where cooling liquid will be passing thorough?
i watched tutorial but most of them are doing this analysis on CFD Ansys. What should be the best possible procedure?
