nikhil12345
 Sir, Thanks for the reply,
Here is the pic of ping localhost.
 Sir, I don't know to change the local user name and if I change it will it work? As I am getting local server error or could not connect to the license server.
Can you specify the reason? This was one or two weeks back, I had version 19.2 which got the same error so I uninstalled it and installed it again it got the same error so now I installed this new version. And it shows the same error. So can you please help me out. And now I again installed it, should I set an environment variable for license and should I install the license manager and license server.
The new error is that could not connect to any license server and could not connect to local host,
Thank you
