nikhil12345
Hello sir, I found this while searching servers and other stuff,
which reads as,
NORMAL STARTUP 2019/04/29 22:51:22
ANSYS Licensing Interconnect version 1.9.7 (20181112) for winx64.  Updated at ANSYS Release 2019 R1.  Started on 2019/04/29 22:51:22 by NEHA A@DESKTOP-16M8SC3:winx64 with pid 8212.
(C) 2007 - 2019 ANSYS, Inc.  Unauthorized use, distribution, or duplication is prohibited.
Built Using FlexNet Publisher v11.13.1.4 build 179569 x64_n6
Built Using OpenSSL 1.1.0i  14 Aug 2018
Please note that entries in this debug log have the following format:
TIMESTAMP              ACTION              FEATURE                    REVISION (BUILD DATE)             A/B/C/D                 W/X/Y/Z   PID:MPID:APP:USER@HOSTLATFORMISPLAY                                    SOCKET:IP
Licenses statistics:
A is the number of licenses requested by this ACTION.
B is the number of licenses used by this USER.
C is the number of licenses used by all users.
D is the number of licenses available in the local license pool.
License server performance statistics:
W is the number of currently connected client applications.
X is the maximum number of connected client applications.
Y is the unique serial number of this client application.
Z is the number of all client applications served by this Licensing Interconnect server.
2019/04/29 22:51:22    INFO                ANSYSLI_CMD=C:Program FilesANSYS IncANSYS StudentShared FilesLicensingwinx64ansysli_client.exe -nodaemon -demo -log C:UsersNEHAA~1AppDataLocalTemp.ansysdemo.log
2019/04/29 22:51:22    INFO                ANSYSLI_INITIALIZATION_FILE=No initialization file found.
2019/04/29 22:51:22    INFO                ANSYSLI_PRODORD_FILE='C:Program FilesANSYS IncANSYS StudentShared FilesLicensingprodordansysli.prodord.xml'
2019/04/29 22:51:24    INFO                ANSYSLI_DEMO_PORT=49699
2019/04/29 22:51:24    INFO                ANSYSLI_CLIENT_IDLE_TIMEOUT=10
2019/04/29 22:53:20    INFO                Ready to accept connections.
2019/04/29 22:53:21    HANDSHAKE_ERROR        1/1/1/1        65488:127.0.0.1
System error: 10053 "An established connection was aborted by the software in your host machine.
2019/04/29 22:536    INFO                License server shutdown is complete. Thank you.
NORMAL STARTUP 2019/04/29 22:53:52
ANSYS Licensing Interconnect version 1.9.7 (20181112) for winx64.  Updated at ANSYS Release 2019 R1.  Started on 2019/04/29 22:53:52 by NEHA A@DESKTOP-16M8SC3:winx64 with pid 9860.
2019/04/29 22:53:52    INFO                ANSYSLI_CMD=C:Program FilesANSYS IncANSYS StudentShared FilesLicensingwinx64ansysli_client.exe -nodaemon -demo -log C:UsersNEHAA~1AppDataLocalTemp.ansysdemo.log
2019/04/29 22:53:52    INFO                ANSYSLI_INITIALIZATION_FILE=No initialization file found.
2019/04/29 22:53:52    INFO                ANSYSLI_PRODORD_FILE='C:Program FilesANSYS IncANSYS StudentShared FilesLicensingprodordansysli.prodord.xml'
2019/04/29 22:53:55    INFO                ANSYSLI_DEMO_PORT=49704
2019/04/29 22:53:55    INFO                ANSYSLI_CLIENT_IDLE_TIMEOUT=10
2019/04/29 22:55:50    INFO                Ready to accept connections.
2019/04/29 22:55:50    HANDSHAKE_ERROR        1/1/1/1        65488:127.0.0.1
2019/04/29 22:56:09    INFO                License server shutdown is complete. Thank you.
NORMAL STARTUP 2019/04/29 23:21:09
ANSYS Licensing Interconnect version 1.9.7 (20181112) for winx64.  Updated at ANSYS Release 2019 R1.  Started on 2019/04/29 23:21:09 by NEHA A@DESKTOP-16M8SC3:winx64 with pid 10568.
2019/04/29 23:21:09    INFO                ANSYSLI_CMD=C:Program FilesANSYS IncANSYS StudentShared FilesLicensingwinx64ansysli_client.exe -nodaemon -demo -log C:UsersNEHAA~1AppDataLocalTemp.ansysdemo.log
2019/04/29 23:21:09    INFO                ANSYSLI_INITIALIZATION_FILE=No initialization file found.
2019/04/29 23:21:09    INFO                ANSYSLI_PRODORD_FILE='C:Program FilesANSYS IncANSYS StudentShared FilesLicensingprodordansysli.prodord.xml'
2019/04/29 23:21:11    INFO                ANSYSLI_DEMO_PORT=55719
2019/04/29 23:21:11    INFO                ANSYSLI_CLIENT_IDLE_TIMEOUT=10
2019/04/29 23:23:15    INFO                Ready to accept connections.
2019/04/29 23:23:15    HANDSHAKE_ERROR        1/1/1/1        65488:127.0.0.1
2019/04/29 23:230    INFO                License server shutdown is complete. Thank you.
NORMAL STARTUP 2019/04/29 23:24:07
ANSYS Licensing Interconnect version 1.9.7 (20181112) for winx64.  Updated at ANSYS Release 2019 R1.  Started on 2019/04/29 23:24:07 by NEHA A@DESKTOP-16M8SC3:winx64 with pid 7668.
2019/04/29 23:24:07    INFO                ANSYSLI_CMD=C:Program FilesANSYS IncANSYS StudentShared FilesLicensingwinx64ansysli_client.exe -nodaemon -demo -log C:UsersNEHAA~1AppDataLocalTemp.ansysdemo.log
2019/04/29 23:24:07    INFO                ANSYSLI_INITIALIZATION_FILE=No initialization file found.
2019/04/29 23:24:07    INFO                ANSYSLI_PRODORD_FILE='C:Program FilesANSYS IncANSYS StudentShared FilesLicensingprodordansysli.prodord.xml'
2019/04/29 23:24:09    INFO                ANSYSLI_DEMO_PORT=58710
2019/04/29 23:24:09    INFO                ANSYSLI_CLIENT_IDLE_TIMEOUT=10
2019/04/29 23:26:07    INFO                Ready to accept connections.
2019/04/29 23:26:07    HANDSHAKE_ERROR        1/1/1/1        65788:127.0.0.1
2019/04/29 23:26:21    INFO                License server shutdown is complete.
This might help you solve the problem and sorry for troubling you guys.
Thank you.
