Mike Rife
Abdul
Which material model was used?  Remember that the metal plasticity material models assume the the plastic strain region slopes do not curve down and turn negative.  This is a theory assumption.  The second question would be what is the material test data format - engineering or true stress-strain.  If engineering did you transform it for input into Ansys WB Engineering Data?  And did you solve this with large deformation turned on?
MIke
