usama
Dear rwoolhou and @peteroznewman
I have dimensions for big circle 300 mm small circle 100 mm and the difference between two big circles 5 micrometer. And patterns (H/W=30/40)
If i multiple these dimensions 300mm×1000
100mm×1000
5 micrometer×1000
And patterns 30 micrometer×1000
40 micrometer×1000
For the CAD
And mesh them and put it into fluent and scale up
Does the dimensions and meshing will change?
I will use multiphase with open channel B.Cs in fluent
And i set surface tension between two phases 0.03 (N/m) with wall adhesion B.Cs
Does these things can simulte for what i want?
Like as you said about surface tension effects?
Regards
Usama
