FlowMoMcFadden
My previous two posts have the transcripts from the "Workbench --> Update Solution" and the "Fluent --> Initialize and Calculate"
I did not change anything in the input file.  Its obvious to me that Fluent is not using the same input parameters in the solution file when commanded to by Workbench.  In this case it is the Solution Steering and FMG settings.  This means that any Workbench feature such as "Response Surface Optimization", "Parameter Correlation" and others will not solve in the manner intended by the user.  I think this is a substantial software bug that should be addressed.  I'd like to know if there is an easy workaround and would appreciate any advice.
