riteshnw
Following is the data inside text file.
*** NOTE ***                            CP =       0.484   TIME= 14:00:21
 The /CONFIG,NOELDB command is not valid in a Distributed ANSYS
 solution.  Command is ignored.
 *GET  _WALLSTRT  FROM  ACTI  ITEM=TIME WALL  VALUE=  14.0058333
 TITLE=
 H-EX.0--Static Structural (A5)
 SET PARAMETER DIMENSIONS ON  _WB_PROJECTSCRATCH_DIR
  TYPE=STRI  DIMENSIONS=      248        1        1
 PARAMETER _WB_PROJECTSCRATCH_DIR(1) = D:RITESHMS Study MaterialWorkspaces-20190324T131209Z-001Workspaces-20190324T131209Z-001_ProjectScratchScr1A86
 SET PARAMETER DIMENSIONS ON  _WB_SOLVERFILES_DIR
 PARAMETER _WB_SOLVERFILES_DIR(1) = D:RITESHMS Study MaterialWorkspaces-20190324T131209Z-001Workspaces-20190324T131209Z-001H-EX.0_filesdp0SYSMECH
 SET PARAMETER DIMENSIONS ON  _WB_USERFILES_DIR
 PARAMETER _WB_USERFILES_DIR(1) = D:RITESHMS Study MaterialWorkspaces-20190324T131209Z-001Workspaces-20190324T131209Z-001H-EX.0_filesuser_files
 --- Data in consistent NMM units. See Solving Units in the help system for more
 MPA UNITS SPECIFIED FOR INTERNAL
  LENGTH      = MILLIMETERS (mm)
  MASS        = TONNE (Mg)
  TIME        = SECONDS (sec)
  TEMPERATURE = CELSIUS (C)
  TOFFSET     = 273.0
  FORCE       = NEWTON (N)
  HEAT        = MILLIJOULES (mJ)
 INPUT  UNITS ARE ALSO SET TO MPA
 *** ANSYS - ENGINEERING ANALYSIS SYSTEM  RELEASE 2019 R1          19.3     ***
 DISTRIBUTED ANSYS Mechanical Enterprise
 00000000  VERSION=WINDOWS x64   14:00:21  MAY 02, 2019 CP=      0.546
          ***** ANSYS ANALYSIS DEFINITION (PREP7) *****
 *********** Nodes for the whole assembly ***********
 Database allocation failed  idbptr=      6448218240  nPageInCore=       16384  -db       -2048 set
 *** ERROR ***                           CP =      49.484   TIME= 14:021
 An unexpected error ( SIG$SEGV ) has occurred...  ANSYS internal data
 has been corrupted.  ANSYS is unable to recover and will terminate.
 Previously saved files are unaffected.  Please send the data leading
 to this operation to your technical support provider, as this will
 allow ANSYS, Inc to improve the program.
 Current ANSYS Traceback:
     ndputList_mp
     ndputList
     nblock-store
     nblock
     pr7nod
     prep7
     prepcl
     ANSYS
 ERROR: Slave process(es) with rank(s) 1 have encountered a FATAL error.
 The information below was gathered from the file*.out output file(s).
 Please review the slave process output file(s) listed below for more
 details on this error.
 Slave Process Output File .file1.out:
 *** FATAL ***                           CP =       0.312   TIME= 14:024
 Check processor 0 (master) for error message(s).
