slouie
Hi Exabit,
Instead of using Optimetrics->Parameters->View Analysis Results, have you tried using our Reporter to view results? I'm not sure which solver you're using, but it's close to the same procedure in any design type. Let's assume it's HFSS -- you would use reporter by navigating to HFSS>>Results>>Create Report
In the Create Report pop-up, there's a Families tab which allows you to select which variation(s) you'd like to plot.
Hope that helps!
