mchristi
We have no record of that error message.
To debug Maxwell projects like this, try divide and conquer approach by simplifying to remove any extra details. Specifically:
  • Reduce model to a single coil solve
  • If this works, add 2nd coil
  • If this works, add the core
  • If this works add remaining complexity
In this way, you should be able to determine the part of the model which is causing the problem.
