DrAmine
To know if your fluid might cavitate you can calculate the cavitation number or cavitation coefficient (denominator is the pressure difference between inlet and outlet). Are you sure that the author fixed the inlet pressure? Generally one fix the outlet pressure and varies the inlet pressure
