Tamoor
   Thank you for your reply Amine, I modelled only the fluid domain with no separate walls, I have attached snapshots of geometry (inlet is at bottom, outlet at top, one side is symmetry and three walls from which heat is to be removed). Also attached you will find cell zone and boundary conditions. Your help is highly appreciated.
Kind regards,
Tamoor
