JakeC
Hi Sam,
Which of the two example that you provided are NOT working?
The Export command is:
export LD_LIBRARY_PATH=/usr/local/libusr/libusr/local/lib64usr/lib64
I don't know if the forum will allow me to post it and not convert the : and / to a smiley.
If the above line is still converted to smiley faces, just replace the smiley with a colon and a forward slash.
Thank you,
Jake
