ansysuser
I only used the gas phase in that simple model.  Yes, in DesignModeler I split the lower wall into 3 parts so that I could put a flux on only a small section.  You can put the igniting flux wherever you need it.  You can avoid stopping the simulation by using the "Execute Commands" found in "Calculation Activities".  Simply enter the command to switch the boundary condition to zero flux or whatever at the appropriate time step.
