Adjust to touch simply offsets the contact surface elements (which are created on the face of the solid elements) by an amount that makes the gap zero.
It is exactly what is done in the Offset method where you can type in a specific value to move the contact elements.
With either method, there is no moving the structural nodes so no change in stiffness is made.
If this answers your question, please click the Is Solution link below, or ask a followup question.
