AnnaYang
Hi jj77,
A hydrostatic bearing is adopted in this machine, so the bearing is the oil film (fluid part which is suppressed in solid solver).
And yes, there are other parts to fix the spindle, I will check the rest contacts between these parts and try the Static Structural again after that.
Thank you for your suggestions, they are very helpful!
