June 27, 2019 at 3:49 pm
Thank you for your response. I am using the latest version 2019R2.
I will try that, I think in that case it will reread the case file and it might take a while again. I tried changing the parameters while fluent is open when I click on the refresh button on the top, it only refreshes the input parameters, which is fast. I think that would be great if the same way could be enabled in the automated parametric study.
