Flippy
The output message is shown here.
=================output message============================================
RELEASE= Release 18.0         BUILD= 18.0      UP20161219   VERSION=WINDOWS x64
 CURRENT JOBNAME=file  133:55  JUN 27, 2019 CP=      0.125
 PARAMETER _DS_PROGRESS =     999.0000000
 /INPUT FILE= ds.dat  LINE=       0
 DO NOT WRITE ELEMENT RESULTS INTO DATABASE
 *GET  _WALLSTRT  FROM  ACTI  ITEM=TIME WALL  VALUE=  13.5652778
 TITLE=
 test1--Static Structural (F5)
 SET PARAMETER DIMENSIONS ON  _WB_PROJECTSCRATCH_DIR
  TYPE=STRI  DIMENSIONS=      248        1        1
 PARAMETER _WB_PROJECTSCRATCH_DIR(1) = C:Users1155049058Desktopmiddle testAnsys FEA_ProjectScratchScr2180
 SET PARAMETER DIMENSIONS ON  _WB_SOLVERFILES_DIR
 PARAMETER _WB_SOLVERFILES_DIR(1) = C:Users1155049058Desktopmiddle testAnsys FEAtest1_filesdp0SYS-5MECH
 SET PARAMETER DIMENSIONS ON  _WB_USERFILES_DIR
 PARAMETER _WB_USERFILES_DIR(1) = C:Users1155049058Desktopmiddle testAnsys FEAtest1_filesuser_files
 --- Data in consistent NMM units. See Solving Units in the help system for more
 MPA UNITS SPECIFIED FOR INTERNAL
  LENGTH      = MILLIMETERS (mm)
  MASS        = TONNE (Mg)
  TIME        = SECONDS (sec)
  TEMPERATURE = CELSIUS (C)
  TOFFSET     = 273.0
  FORCE       = NEWTON (N)
  HEAT        = MILLIJOULES (mJ)
 INPUT  UNITS ARE ALSO SET TO MPA
 *** ANSYS - ENGINEERING ANALYSIS SYSTEM  RELEASE Release 18.0     18.0     ***
 ANSYS Multiphysics
 00000000  VERSION=WINDOWS x64   133:55  JUN 27, 2019 CP=      0.203
          ***** ANSYS ANALYSIS DEFINITION (PREP7) *****
 *********** Nodes for the whole assembly ***********
 *********** Elements for Body 1 "fiber_Line Body" ***********
 *********** Elements for Body 2 "mid" ***********
 *********** Elements for Body 3 "top" ***********
 *********** Elements for Body 4 "btm" ***********
 *********** Elements for Body 5 "spring_line" ***********
 *********** Send User Defined Coordinate System(s) ***********
 *********** Set Reference Temperature ***********
 *********** Send Materials ***********
 *********** Send Beam Properties ***********
 *********** Create Contact "Contact Region" ***********
             Real Constant Set For Above Contact Is 7 & 6
 *********** Create Contact "Contact Region 2" ***********
             Real Constant Set For Above Contact Is 9 & 8
 *********** Create Contact "Bonded - fiber_Line Body To mid" ***********
             Real Constant Set For Above Contact Is 11 & 10
 *********** Create Contact "Bonded - spring_line To mid" ***********
             Real Constant Set For Above Contact Is 13 & 12
 *********** Create Contact "Bonded - spring_line To btm" ***********
             Real Constant Set For Above Contact Is 15 & 14
 *********** Create Contact "Bonded - spring_line To top" ***********
             Real Constant Set For Above Contact Is 17 & 16
             Real Constant Set For Above Contact Is 19 & 18
             Real Constant Set For Above Contact Is 21 & 20
 *********** Fixed Supports ***********
 *********** Define Pressure Using Surface Effect Elements ***********
 LIST DATA TABLE  HYPE  FOR MATERIAL      5
 ANSYS Multiphysics
 00000000  VERSION=WINDOWS x64   133:55  JUN 27, 2019 CP=      0.469
               HYPER EL (HYPE) Table For Material     5
               Hyperelastic mat. Option - NEO-HOOKEAN
                     1
 Temps     0.0000000e+000
 mu       2.4000000e-001
 d        0.0000000e+000
 ***** ROUTINE COMPLETED *****  CP =         0.469
 --- Number of total nodes = 38522
 --- Number of contact elements = 7770
 --- Number of spring elements = 0
 --- Number of bearing elements = 0
 --- Number of solid elements = 6906
 --- Number of total elements = 16891
 *GET  _WALLBSOL  FROM  ACTI  ITEM=TIME WALL  VALUE=  13.5652778
 *************************    SOLUTION       ********************************
 *****  ANSYS SOLUTION ROUTINE  *****
 PERFORM A STATIC ANALYSIS
  THIS WILL BE A NEW ANALYSIS
 LARGE DEFORMATION ANALYSIS
 USE SPARSE MATRIX DIRECT SOLVER
 CONTACT INFORMATION PRINTOUT LEVEL       1
 NLDIAG: Nonlinear diagnostics CONT option is set to ON.
         Writing frequency : each ITERATION.
 DEFINE RESTART CONTROL FOR LOADSTEP LAST
 AT FREQUENCY OF LAST AND NUMBER FOR OVERWRITE IS    0
 DELETE RESTART FILES OF ENDSTEP
 ******************* SOLVE FOR LS 1 OF 1 ****************
 SELECT       FOR ITEM=TYPE COMPONENT=
  IN RANGE        22 TO         22 STEP          1
       1832  ELEMENTS (OF      16891  DEFINED) SELECTED BY  ESEL  COMMAND.
 SELECT      ALL NODES HAVING ANY ELEMENT IN ELEMENT SET.
     5622 NODES (OF    38522  DEFINED) SELECTED FROM
     1832 SELECTED ELEMENTS BY NSLE COMMAND.
 GENERATE SURFACE LOAD PRES ON SURFACE DEFINED BY ALL SELECTED NODES
 SET ACCORDING TO TABLE PARAMETER = _LOADVARI61
 NUMBER OF PRES ELEMENT FACE LOADS STORED =       1832
 ALL SELECT   FOR ITEM=NODE COMPONENT=
  IN RANGE         1 TO      38522 STEP          1
      38522  NODES (OF      38522  DEFINED) SELECTED BY NSEL  COMMAND.
 ALL SELECT   FOR ITEM=ELEM COMPONENT=
  IN RANGE         1 TO      16891 STEP          1
      16891  ELEMENTS (OF      16891  DEFINED) SELECTED BY  ESEL  COMMAND.
 PRINTOUT RESUMED BY /GOP
 USE AUTOMATIC TIME STEPPING THIS LOAD STEP
 USE       5 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL  DEGREES OF FREEDOM
 FOR AUTOMATIC TIME STEPPING:
   USE   1000 SUBSTEPS AS A MAXIMUM
   USE      1 SUBSTEPS AS A MINIMUM
 TIME=  1.0000
 ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
 WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
   FOR ALL APPLICABLE ENTITIES
 WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE STRS ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EPEL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EPPL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE MISC ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
   FOR THE ENTITIES DEFINED BY COMPONENT _ELMISC
 NONLINEAR STABILIZATION CONTROL:
 KEY=OFF
 NLDIAG: Nonlinear diagnostics NRRE option is set to ON.
 The number of files/iterations to be saved for NRRE nonlinear diagnostics has been set to   4
 *GET  ANSINTER_  FROM  ACTI  ITEM=INT        VALUE=  0.00000000
 *IF  ANSINTER_                         ( =   0.00000       NE
      0                                 ( =   0.00000       THEN
 *ENDIF
 *****  ANSYS SOLVE    COMMAND  *****
 *** WARNING ***                         CP =       0.500   TIME= 133:55
 Element shape checking is currently inactive.  Issue SHPP,ON or
 SHPP,WARN to reactivate, if desired.
 *** NOTE ***                            CP =       0.516   TIME= 133:55
 The model data was checked and warning messages were found.
  Please review output or errors file (
 FEA_ProjectScratchScr2180file.err ) for these warning messages.
 *** SELECTION OF ELEMENT TECHNOLOGIES FOR APPLICABLE ELEMENTS ***
      --- GIVE SUGGESTIONS AND RESET THE KEY OPTIONS ---
 ELEMENT TYPE    1 IS BEAM188 . KEYOPT(3) IS ALREADY SET AS SUGGESTED AND NO
 RESETTING IS NEEDED.
 ELEMENT TYPE    1 IS BEAM188 . KEYOPT(15) IS ALREADY SET AS SUGGESTED AND NO
 ELEMENT TYPE    2 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED. SINCE IT IS
 ASSOCIATED WITH FULLY INCOMPRESSIBLE HYPERELASTIC MATERIALS, KEYOPT(6)=1
 MUST BE USED. THEY HAVE BEEN RESET.
  KEYOPT(1-12)=    0    0    0    0    0    1    0    0    0    0    0    0
 ELEMENT TYPE    3 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
  KEYOPT(1-12)=    0    0    0    0    0    0    0    0    0    0    0    0
 ELEMENT TYPE    4 IS SOLID186. KEYOPT(2)=0 IS SUGGESTED AND HAS BEEN RESET.
 ELEMENT TYPE    5 IS BEAM188 . KEYOPT(3) IS ALREADY SET AS SUGGESTED AND NO
 ELEMENT TYPE    5 IS BEAM188 . KEYOPT(15) IS ALREADY SET AS SUGGESTED AND NO
 ANSYS Multiphysics
 00000000  VERSION=WINDOWS x64   133:55  JUN 27, 2019 CP=      0.516
                       S O L U T I O N   O P T I O N S
   PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D
   DEGREES OF FREEDOM. . . . . . UX   UY   UZ   ROTX ROTY ROTZ
   ANALYSIS TYPE . . . . . . . . . . . . . . . . .STATIC (STEADY-STATE)
   OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . .  273.15
   NONLINEAR GEOMETRIC EFFECTS . . . . . . . . . .ON
   EQUATION SOLVER OPTION. . . . . . . . . . . . .SPARSE
   PLASTIC MATERIAL PROPERTIES INCLUDED. . . . . .YES
   NEWTON-RAPHSON OPTION . . . . . . . . . . . . .PROGRAM CHOSEN
   GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRIC
 *** ERROR ***                           CP =       0.531   TIME= 133:55
 BEAM188 element number 6276 does not support hyperelastic material 5.
 *** WARNING ***                         CP =       0.547   TIME= 133:55
 Material number 22 (used by element 15060 ) should normally have at
 least one MP or one TB type command associated with it.  Output of
 energy by material may not be available.
 *** ERROR ***                           CP =       0.562   TIME= 133:55
 The step data was checked and there were errors found.
  Please check output or errors file (
 FEA_ProjectScratchScr2180file.err ) for messages.
 *** NOTE ***                            CP =       0.562   TIME= 133:55
 This nonlinear analysis defaults to using the full Newton-Raphson
 solution procedure.  This can be modified using the NROPT command.
 The conditions for direct assembly have been met.  No .emat or .erot
 files will be produced.
 NUMBER OF WARNING MESSAGES ENCOUNTERED=          2
 NUMBER OF ERROR   MESSAGES ENCOUNTERED=          2
 ***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
A N S Y S   S T A T I S T I C S
Release: Release 18.0       Build: 18.0       Update: UP20161219   Platform: WINDOWS x64
Date Run: 06/27/2019   Time: 133     Process ID: 2700
Operating System: Windows 10  (Build: 17763)
Processor Model: Intel(R) Core(TM) i5-7400 CPU @ 3.00GHz
Compiler: Intel(R) FORTRAN Compiler Version 15.0.7  (Build: 20160518)
          Intel(R) C/C++ Compiler Version 15.0.7  (Build: 20160518)
          Intel(R) Math Kernel Library Version 11.3.3 Product Build 20160413
Number of machines requested            :    1
Total number of cores available         :    4
Number of physical cores available      :    4
Number of processes requested           :    1
Number of threads per process requested :    2
Total number of cores requested         :    2 (Shared Memory Parallel)
GPU Acceleration: Not Requested
Job Name: file
Working Directory: C:Users1155049058Desktopmiddle testAnsys FEA_ProjectScratchScr2180
Total CPU time for main thread                    :        0.6 seconds
Total CPU time summed for all threads             :        0.6 seconds
Elapsed time spent pre-processing model (/PREP7)  :        0.2 seconds
Elapsed time spent solution - preprocessing       :        0.1 seconds
Elapsed time spent computing solution             :        0.0 seconds
Elapsed time spent solution - postprocessing      :        0.0 seconds
Elapsed time spent post-processing model (/POST1) :        0.0 seconds
Maximum total memory used                         :       37.0 MB
Maximum total memory allocated                    :     2112.0 MB
Total physical memory available                   :          8 GB
