DineshKanesan123
Thank you very much for the explanation. I did try adding other solid materials before deleting aluminum but it didnt work. However, since the erosion models use the parameters in the dpm tab, is changing the density of aluminum in the material properties to the density of stainless steel sufficient for modeling erosion in stainless steel pipes ?
