tsiriaks
Google translation
"friends if they have this problem, but they can open the spaceclaim. Work your geometry in the spaceclaim and then from the interface of the spaceclaim export the geometry in IGES and then import this IGES into the WORKBENCH. Although it is not a definitive solution, it will allow them to work on their models without having the error."
Thank you for the suggestion of the workaround jmartinezs1992 . It's ideal to make it works with SpaceClaim but if issue persists after all suggestions, your workaround is one way to circumvent it
Thanks,
Win
