You should run for more iterations (much much more..) and check all other stuff I was mentioning. If the reversal flow is occuring, this might be due to numerical reasons and could disappear or even physical. What you can do is to elongate the outflow region and use realistic backflow quantities at the outlet. Other way (not like it) is to switch on "prevent backflow".
