Venkatesan
Is it ok,if I create ply in ACP Pre for the top plate downwards and bottom plates upwards such that there is no gap between the plates without using the shell thickness effect? Or should I model the plates with mid surface like the picture attachedĀ  with shell thickness effect on and create ply above and below the mid surface for top and bottom plates with offset type set to middle in Geometry Definition?
